Cam Install
Old Dec 19, 2003 | 12:48 AM
96lt1Camaro's Avatar
Cam Install
What is needed? Trying to get a list going on all the things ill be needing for the install. On my list so far i have *CAM,*1.6's, *springs, *oil, *gaskets ofcourse,....(this is where you guys come in). Is there a package i can buy at summit or other online shops?
Old Dec 19, 2003 | 12:52 AM
atljar's Avatar
Heres the list i made when i did mine, not everything is really needed
Vented OptiSpark and lines
cam
95 timing cover, and pigtail
Cloyes Timing chain
Chromemoly Pushrods
Guideplates
7/16 Rocker Stud
Locks
TI retainers
K motion springs
1.6 RR Pro Magnum (7/16)
Valve shims
CSI Waterpump
New serp belt
Oil 11 quarts
2 filters
longer bolt for hub installer
mineral spirits
Blue locktite
Water wetter stuff
assembly lube
intake man gasket
h20 gaskets
timing cover gasket
black rtv
anitfreeze
Old Dec 19, 2003 | 01:38 AM
z28marine's Avatar
11 quarts of oil??
Old Dec 19, 2003 | 01:49 AM
atljar's Avatar
Thats 2 oil changes for cam break in
Old Dec 19, 2003 | 07:52 AM
Hawk350's Avatar
How many miles for the cam to break in?
Old Dec 19, 2003 | 08:04 AM
madhatter's Avatar
Talk to the guys over at Combination Motorsports.
http://www.cmotorsports.com
They will hook you up with everything you need at a good price.
Old Dec 19, 2003 | 08:23 AM
GREGG 97Z's Avatar
Here's a good install guide I used along with a Haynes manual when I did mine:
http://www.streetillusionsracing.com...ll/Cam/cam.htm
Old Dec 19, 2003 | 08:30 AM
yeah friend of mine just told me about cmotorsports, that site is awesome. It carries everything needed for cam install. Even carries gm factory timing chain. Here is their package deals:
http://web.camaross.com/forums/showt...&highlight=cam
Old Dec 19, 2003 | 04:03 PM
atljar's Avatar
I started it up, and gave it various rpms in nuetral for about 10 min, but kept it under 3k.
Drained, changed filter, and refilled. Drove it around for about 2 hours, went to store etc. Drained that and filled with my normal mobile 1. So actually i guess i used 16.5 quarts if you count the mobile change.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
