Cam help please
Old Dec 14, 2003 | 05:15 PM
LT4Z's Avatar
Cam help please
Ok im running the LT4 Hot Cam and i run on nittos threw my cat back exhaust a 12.80 at 107 with a automatic and i was wondering how low would a 230/236 544/555 cam drop my et with a dyno tune.
Old Dec 14, 2003 | 07:21 PM
Smokn '94 Z's Avatar
Lightbulb
Are you an M6 or A4? Your time is solid with the Hot Cam. To ask how much better your times would get with the other cam is hard to say. I am sure it would be better but without knowing your other mods it is hard to tell how much better...
Old Dec 15, 2003 | 02:27 AM
S.J.S.'s Avatar
My thoughts exactly. Do you have any headwork done??? That will play a big part in how well your cam performs.
Old Dec 15, 2003 | 04:03 PM
LT4Z's Avatar
I have a Lt1 that i rebuit 355 and put the LT4 conversion kit on it and with that the Lt4 heads are bone stock with 1.6 roller rockers and ive got shorty hooker headers and 52mm throttle body and 3.73gears and catback exhaust with a mail order tune and i run threw my catback exhaust on nittos 12.8 107 and want to no what size cam could i go with to get to low 12s high 11s with a good dyno tune.
Old Dec 15, 2003 | 05:11 PM
A4 or M6?
Old Dec 15, 2003 | 05:17 PM
LT4Z's Avatar
its a 1994 coupe and whats that mean
Old Dec 15, 2003 | 06:12 PM
AsianSensation's Avatar
Smokn '94 Z meant 4 speed automatic or 6 speed manual.
Old Dec 15, 2003 | 06:32 PM
LT4Z's Avatar
its a automatic.
Old Dec 15, 2003 | 06:39 PM
S.J.S.'s Avatar
Any cam would benefit heavily from a good headjob. If you wanna go bigger and get good results, you will need to open her up a lil. The heads that is. Having a big cam with basically stop heads wont get you near as much as you should.
Old Dec 15, 2003 | 07:31 PM
Camaro_Maniac63's Avatar
Low 12s/high 11s are doable with that 230/236 544/555 cam, stock LT4 heads, a dyno tune, and all the other mods you have. Just get a nice torque converter and some sticky tires. Good luck.
Old Dec 15, 2003 | 10:08 PM
Originally posted by LT4Z
its a automatic.
Well if you get a Torque Converter... 3500ish Stall you will be all over the low 12's with a sticky tire. No matter what cam you run a torque converter will definately otimize the cam but as stated head work is pretty important too, unless your me then you only gain .03 hundreths with GTP's on the same HOT Cam set up. 12.30 to 12.27..
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
