Cam help for my setup..also power #'s
Old Feb 9, 2008 | 11:14 AM
brokencar's Avatar
As soon as i get done fixing all the kinks with my car I'll be adding a cam.. I'm thinking about x306...but I just want a mild cam that can put down good numbers....The was built backwards..it already has the following mods...I don't have a clue what it's pushing right now
ENGINE- ported heads, heads have comp-cams 987 springs and comp-cams harden pushrods, pacesetter long tube headers and 3" ORY pipe, intake comes with SLP's Airfoil, SLP's line-lock to lock the front brakes, brand new opti-spark with new MSD spark plug wires, and NGK GP-series spark plugs
ALSO NEW TIMING CHAIN AND GEARS. new aeromotive fuel pressure regulator, MAF is descreened and ported a little.
TRANSMISSION- Brand New Spec clutch with a Spec steel flywheel cost over a $1000
just finished break in period. also WS6 short Shifter.
SUSPENSION- NEW Blistein front and rear shocks cost over a $100 each, and NEW Eibach ProKit Performance Springs that lowers the car 1.25" in the front and rear
Old Feb 9, 2008 | 11:33 AM
96capricemgr's Avatar
The Aeromotive and hacked MAF are only going to serve to cause problems.
The 306 is NOT a mild cam, sounds to me like you want the 503.
Old Feb 9, 2008 | 09:50 PM
ricehammer's Avatar
Ditto on the 503. Consider getting a set of roller rockers if you don't already have them. 1.6:1 NSA's with guideplates since you already have hardened pushrods.
Old Feb 10, 2008 | 11:16 AM
slingshot's Avatar
As you can see in my sig, I have the cc305, which is a great mild cam. I drive my car year around with the 3400 stall converter and it is a great daily driver.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
InfernalVortex
Jan 17, 2015 09:35 AM
XtremeLt1
Sep 13, 2002 08:50 PM
