Cam dowl change
Old Mar 22, 2007 | 07:41 PM
  #31
camzaro28's Avatar
Originally Posted by 94_PatriotRed_Z
So does anyone know the length of the dowl pin for a non vented opti?
If you are in Daytona right now, just go up to Crane cams and tell them you need the dowel pins for your car and they will give you a couple of both.
That is what I ended up having to do when no shop I went to had one.
Old Mar 22, 2007 | 08:57 PM
  #32
94_PatriotRed_Z's Avatar
Originally Posted by shoebox
If found some old notes in my archives. One said .300" and the other .320". It needs to be long enough to index the cam gear and short enough not to contact the back of the opti. That leaves a lot of leeway.
Thanks for the info. I ordered one today from Fastnal. But it was before I saw this post so it is longer, it is .600" I guess I will have to do some grinding.
Thanks for that info. Im not in Daytona right now, but maybe I can talk my mom in to picking me up one tomorrow. Do you know where it is located in Daytona?
Old Mar 22, 2007 | 09:11 PM
  #33
camzaro28's Avatar
on 530 Fentress, behind Best buy. Couple blocks from Mason IIRC.
If you get on fentress from International, its at the 1st stop sign.
Old Mar 22, 2007 | 09:17 PM
  #34
o yea thanks, my mom works right around the corner from there so hopefully she can pick one up for me
Old Mar 22, 2007 | 09:48 PM
  #35
The bare pin must be longer than .300", because you have to tap it into the cam. .300" is just how far it sticks out.
Old Mar 23, 2007 | 06:54 AM
  #36
Right but I ordered one that sticks out .600" from the end of the cam
Old Mar 23, 2007 | 08:54 AM
  #37
Well I called Crane Cams, they are the one located on Fentress and they said they will ship me out one today for no charge. Thank you guys for all your info. Sorry to take over this thread
IgorT.455/406
Mar 12, 2015 03:39 AM
armedtrigger
Feb 24, 2015 08:30 PM
blac94Z
Feb 18, 2015 11:36 AM
birdblack
Dec 30, 2014 06:59 PM
