cam and computer?
Old Nov 9, 2004 | 09:28 PM
bodydropped's Avatar
cam and computer?
i did a search on this and found nothing,im considering a mild cam swap in my LT1 and headers.i was talking about it with a friend and he said im crazy if i do it, he claims that the factory tuning will not accept this kind of mod.he said he changed rear gears and his computer went crazy he said its because the computer in these cars are very sensitive and its hard to do mods like this.so do i have to get the computer reprogrammed to work with a new cam?
Old Nov 9, 2004 | 11:03 PM
TobyZ28's Avatar
Re: cam and computer?
It'll run without a tune, but you'll probably want to tune it as the spark advance for the new Cam will probably be more/less agressive in different spots.
Gears throw the "computer" off since its used to calculate speed, which is used by the computer in an A4 to determine shift points. If changing the gearing, tire diameter, transmission, you always need to be sure the computer knows the changes or your speedo will be off and your shifts may be messed up. Its not going crazy, just action on what its been told to do
Old Nov 10, 2004 | 11:47 AM
TigerWoodsJr's Avatar
Yeah, it would probably be in your best interest to get a tune just to maximize performance. And like he said, of course gears will throw it off, DUH.
Old Nov 10, 2004 | 06:06 PM
96capricemgr's Avatar
Don't bother swapping parts unless youy are willing to do at least a mailorder tune, but not because of the reasons your friend gave. The car will run probably decently with the stock tune and a cam but you will be leaving a lot of power on the table. Look at it this way would you cam a carbed car without rejetting the carb or resetting the timing, well not reprogramming a computer controled car is the same thing. It is actually pretty amazing how tolerant this pcm can be one of the guys on the b-body forum recently posted numbers at over 600RWHP and almost 700RW TQ, needless to say he has done a few mods, but has also had the pcm reprogrammed to work with them.
Old Nov 10, 2004 | 07:22 PM
who would tune it?where im at in atlanta there are really no domestic tuners mostly imports.atlanta chasis dyno went out of buissness so i have no clue how to get this done or how much to pay and how long does it normally take.if thats what has to be done to make it right then i will get it done i thought it was going to be confusing mess.any suggestions as to who can do this or is there a DIY tune kit for dummies out there?
Old Nov 10, 2004 | 07:25 PM
ChevyTuffD.A.'s Avatar
Contact PCMforless or Madwolf here on the boards, they offer mail order tunes that are very accurate and will offer great power gains with your cam.
Old Nov 10, 2004 | 07:39 PM
hosspwr94's Avatar
Also Ed Write out of Tulsa Oklahoma (close to my house ) Does the mail order call him at 918-446-3019 You'll talk to John but they can get you a good tune and will also do upgrades for you later after you've changed your mind and want a gm847 or a cc306!! And Trust me you'll want bigger
Good luck
Les
Old Nov 10, 2004 | 07:52 PM
Ed is good but Madwolf and pcmforless can produce the same results at a fraction the price. As far as wanting a bigger cam, honestly I think most of the f-body crowd overdoes it(as do many b-body guys) isn't one of the quicker cammed cars a 227 cam and the 845/227/ZZ3 cams all do well in the b-body and those are 208-14 on the intake mild but very good performers.
Old Nov 10, 2004 | 09:31 PM
hosspwr94's Avatar
Yes those are good cams But then that all depends on what you want! I went with the 306 cam because I am running nitrous and a mild cam is not what runs well on nos!! if you are just wanting a great street performer then the 845 or even the 227 are good but if you plan on some good track times and great street performance then the bigger the better. I have yet to see too many b-bodies get in the 9's and 10's with those smaller cams.
Old Nov 10, 2004 | 09:39 PM
thanks for the info,and mild is all i need i dont want to push this motor to hard.if it were rebuilt then i would run a bigger cam im just looking for a more agressive sound and improved power from a launch.but mostly i just love the sound of a big cam.
Old Nov 10, 2004 | 09:41 PM
hosspwr94's Avatar
If I may ask, what cam are you going with?
Old Nov 10, 2004 | 10:13 PM
well im looking at a crane LT1 cam part # cra104241 a local parts shop sells (barnett performance) they run about 270.00 and then i need springs to go with it.
MadMav
May 25, 2015 09:35 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
armedtrigger
Feb 24, 2015 08:30 PM
InfernalVortex
Jan 17, 2015 09:35 AM
