? on cam bearings...
Old Mar 19, 2005 | 12:27 PM
madhatter's Avatar
Ok, if I pull out the stock cam and see that mine are really worn, can I just put the stock cam back in? Is it possible to change them out while in the car?
-Sean
Old Mar 19, 2005 | 02:57 PM
Pasky's Avatar
Re: ? on cam bearings...
You'd have to pull the tranny and pop a freeze plug to get to the back cam bearing and its not worth the trouble, easier to lift the car out of the engine bay and replace them there.
Old Mar 19, 2005 | 03:02 PM
madhatter's Avatar
Well, is it ok to put the stock cam back in if they are FUBARd?
Old Mar 19, 2005 | 03:28 PM
Pasky's Avatar
I wouldn't, you know its messed up, just a matter of time before you have to pull it out and put new ones in anywyas. Your already there, why not? The tool is like $40, cam bearings are $15, rent a cherry picker for a day for $75 and just lift it out of the car to replace them. Your asking for trouble if you just put it back IMO.
Old Mar 19, 2005 | 04:49 PM
87slyroc's Avatar
not to mention that it would be really hard to get the front four out in the car. even if you remove the shroud, radiator and condensor, there's still not a heck of alot of room to get the tool in correctly. and if you can tell that they are worn without giving them a thorough inspection with the engine out, then they are way past there usage life. just my thoughts....
Old Mar 19, 2005 | 07:06 PM
You would have to remove the engine to do all the cam bearings. If you just stuck the cam back in, it would not be any worse off than what it was before.
Old Mar 19, 2005 | 08:06 PM
LT1 Bunny's Avatar
i agree with shoebox, you would have to pull the motor out to replace the cam bearings. I'll check that tool out, the way I've done cam bearings is to take everything apart and tap them in with a wooden hammer. Thats the way we do them all in the shop.
Old Mar 20, 2005 | 10:32 AM
TCAL95Z's Avatar
Hi Sean,
Ya I think you could put the stock cam back in but on Matts car when the cam cam out they were so bad there was no point in putting the cam back in.
Its not like I've done a thousand cam swaps but I've done several and his cam didn't want to come out. I have never seen that before so If the cam doesn't want to come out easy leave it in.
What are you looking to put in and how soon? want any help?
Old Mar 20, 2005 | 01:16 PM
madhatter's Avatar
Originally Posted by TCAL95Z
Hi Sean,
Tom,
Give me a call sometime and we can talk engines. My number is on AZFBA.
-Sean
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
