Cam
Old Mar 16, 2003 | 11:09 PM
  #16
ChrisJ325's Avatar
Originally posted by oldBones
Here is my favorite step by step install page,if I can make this work.
www.streetillusionsracing.com
I used this guide in my cam swap Im working on right now. Its very helpful
Old Mar 16, 2003 | 11:14 PM
  #17
smokindastangs's Avatar
I disaggree, i think that you should get more out of the cc306; but tht doesn't really matter. Do not get LT1 edit, TunerCat or anything like that unless you are planning to spend a long while learning it. They are not exactly user friendly. I would recommend getting you car dyno-tuned. I believe that you will find the best results that way. It might be a little more pricy,(150.00 per hr) but if you are going to put this cam in ( hopefully heads too ) you should spend the extra $$ and do it right! If you don't, you won't be happy w/ the results.
Old Mar 17, 2003 | 02:46 PM
  #18
LT1 Bunny's Avatar
I had the website where to buy the XE224/230 but now I cant find it. I looked on COMPCAMS.COM but I keep getting the run around...is there any other site I can get this from? I already tried thunderracing.com too they dont have it.
Old Mar 17, 2003 | 06:59 PM
  #19
LT1 Bunny's Avatar
Hey, I had the credit card in my hand ready to oreder but I can't find the website I was at! Does anyone know where I can find an XE224/230 cam?? I went on Comp Cams and had no luck...but I'll try looking harder. Summit doesnt have it and neither does thunderracing. Thanks again!
Old Mar 17, 2003 | 10:59 PM
  #20
JJ's95B4C's Avatar
These guys have a great deal on everything you need to do the cam.
http://www.cmotorsports.com/
Old Mar 17, 2003 | 11:07 PM
  #21
turbo_Z's Avatar
thunder racing has the cam. but order it from combination motorsports... the link given in the previous post. their customer service is top notch!
Old Mar 18, 2003 | 12:11 AM
  #22
pennys58's Avatar
Here is a pretty good website that has the cam...it is 215.00 and I am ordering the same one from there...http://www.lt1f-body.racenet.net/valvetrain.php
it is under the XE cams..i.e. extreme energy.
Old Mar 18, 2003 | 03:37 PM
  #23
LT1 Bunny's Avatar
Okay I have one last question...I have a comp cams catalogue and it says here that there is an XE cam that has a duration of 210/220 at .050 and a lift of .500/.510 lobe is 114. How much HP and TQ is the 224/230 going to give me? How much will the 210/220 give me? I am going to get the 224/230 but I was just curious as to how much power I am going to get from one versus another. Thanks everyone for the help!
Old Mar 18, 2003 | 11:45 PM
  #24
Zdawg's Avatar
Whoa.....just ask around about Racenet's customer service. I wouldn't order Top Ramen from those guys
Old Mar 18, 2003 | 11:53 PM
  #25
pennys58's Avatar
Yeah, funny you mention that because last night I searched on racenet and really found out a lot about them. That is really messed up...however, I am local and not far from them ~20mins, so if they don't come through then I'm right here to correct the problem effectively and efficiently.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
