Call me crazy but...
Old Jun 23, 2003 | 11:41 PM
LT1FlaGuy's Avatar
Lightbulb Call me crazy but...
So here i was breaking rr stud bolts left and right.... So i thought to myself... instead of going thru the hassle of a valve spring job.. what if just go to a 1.5 rocker and ditch the 1..6's so i go over to Performance Plus and pick up a set of Comp Cams 1.5 rr's spend the next 6 hrs taking the old ones off... putting the new ones on.. adjusting.. re-adjusting... fighting with the valve cover gaskets... so i get it done... pull out of the garage.. stomp it.. and.. all at the same time... It took off like a bat outa hell .. these rockers obviously matched my set up way better then the crane gold 1.6's so now i am going to sit back... and pray that everything stays well...
Thanks to everyone that helped me out on this earlier today and yesterday.. you guys kick ***
Old Jun 23, 2003 | 11:43 PM
GhostZ's Avatar
I'm going to have to call you crazy.
Old Jun 24, 2003 | 12:20 AM
revtime's Avatar
So I guess it was the coil bind thing huh?
Old Jun 24, 2003 | 12:34 AM
Z-RATED94's Avatar
Did you at least change your oil and filter after all of that. A magnetic oil pan plug would be nice too.
Old Jun 24, 2003 | 04:22 AM
LT1FlaGuy's Avatar
from the look of things yes it was coil bind... im going to do the oil and filter first thing in the morning... wait.. its 530 am.. i guess it is first thing in the morning after putting the 1.5's on you could see a visual difference in how far down it was pushing the spring... so... lets just hope it stays this way..
Old Jun 24, 2003 | 06:39 AM
SlowAssTA's Avatar
how much you want for the 1.6's
Old Jun 24, 2003 | 08:29 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
what springs?
6 hrs? damn, it took me 12 hrs to tear apart the whole top end... fighting gaskets
marlar98
Sep 12, 2018 07:18 AM
Daluchman1974
Sep 11, 2015 06:12 AM
mlopezart
Sep 8, 2015 12:15 PM
WPHIG2
Aug 27, 2015 06:37 AM
Boss002
Jul 9, 2015 03:33 PM
