Call me crazy but...
So here i was breaking rr stud bolts left and right.... So i thought to myself... instead of going thru the hassle of a valve spring job.. what if just go to a 1.5 rocker and ditch the 1..6's
so i go over to Performance Plus and pick up a set of Comp Cams 1.5 rr's spend the next 6 hrs taking the old ones off... putting the new ones on.. adjusting.. re-adjusting... fighting with the valve cover gaskets... so i get it done... pull out of the garage.. stomp it.. and..
all at the same time... It took off like a bat outa hell .. these rockers obviously matched my set up way better then the crane gold 1.6's so now i am going to sit back... and pray that everything stays well...
Thanks to everyone that helped me out on this earlier today and yesterday.. you guys kick ***
all at the same time... It took off like a bat outa hell .. these rockers obviously matched my set up way better then the crane gold 1.6's so now i am going to sit back... and pray that everything stays well... Thanks to everyone that helped me out on this earlier today and yesterday.. you guys kick ***
from the look of things yes it was coil bind... im going to do the oil and filter first thing in the morning... wait.. its 530 am.. i guess it is first thing in the morning
after putting the 1.5's on you could see a visual difference in how far down it was pushing the spring... so... lets just hope it stays this way..
mlopezart
Sep 8, 2015 12:15 PM
