Best Street/Strip shock/spring combo?
Old Jun 23, 2003 | 12:43 PM
chucks97ss's Avatar
Post your opinions here on what you think.... Don't wanna spend a fortune, but this is going to be for a 9 second car so I'm willing to at least do it right. Just no overkill....
Chuck
Old Jun 23, 2003 | 01:06 PM
Josh-'04 GTO's Avatar
9 sec car calls for the HAL setup in my book. Set up soft for strip, then turn the dials for medium or firm on the street. Can't beat that! The whole setup is cheaper than Konis too.
Old Jun 23, 2003 | 01:36 PM
sssalah's Avatar
HAL/QA1 as mentioned above. Its tried, tested and proven part, you can't go wrong there.
Old Jun 23, 2003 | 01:39 PM
chucks97ss's Avatar
What about springs? I'd like to lower the car....
Chuck
Old Jun 23, 2003 | 01:49 PM
sssalah's Avatar
Most poeple here are using Eibach spring for lowering. If you're using the HAL struts and any other spring other than HAL you'll need to modify a stock spring seat to fit over the HAL strut.
By lowering the car you'll run into other problems and you might need LCA lowering bracket.
Old Jun 23, 2003 | 01:52 PM
chucks97ss's Avatar
can you adjust ride height on the HAL's with a spanner wrench?
Chuck
Old Jun 23, 2003 | 02:01 PM
sssalah's Avatar
You can adjust the ride hight on the front HALs with a special wrench, technically known as (square pin adjustable hook wrench), its sold by HAL.
The rears are are only adjustable for firmness and not ride hight.
Old Jun 23, 2003 | 02:56 PM
chucks97ss's Avatar
So can I buy shorter springs from HAL for the back?
Chuck
Old Jun 23, 2003 | 03:56 PM
chucks97ss's Avatar
ttt
Old Jun 23, 2003 | 07:45 PM
chucks97ss's Avatar
ttt
Old Jun 24, 2003 | 03:34 AM
sssalah's Avatar
For the rear spring you can use any brand you like, HAL, Eibach even stock, it doesn't matter becuase the spring and shock are seperate. What counts is the front spring which is a Macpherson or coilover and the HAL strut is slightly bigger in diameter than stock, so if you plan on using anything but the HAL spring on the FRONT struts you'll need to modify a stock spring seat.
Hope this helps.
Old Jun 24, 2003 | 08:36 AM
Mikey97Z's Avatar
I have the HALs in front and back. Their adjustability is awesome!
I lowered the front an inch or two, but the back is still on the stock springs. I'm considering lowering springs for the back, but for a drag launch you want bouncy springs, not stiff. But I think most lowering springs are stiffer than stock. If anyone knows more about springs please chime in!
Old Jun 24, 2003 | 08:41 AM
KCFormula's Avatar
If your car is a 9sec car you are going to want to run at least a 28" slick. That would mean lowering is pretty much out of the question. IMHO I would run Hals with stock springs out back and some 1/2" drop or so up front.
Quickss96
Jan 29, 2016 05:56 PM
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
Timberwolf
Advanced Tech
Aug 5, 2002 10:35 PM
