Caamro electrical systems SUCK...
Old May 9, 2004 | 02:42 PM
crAzy95z28's Avatar
well ok i posted ealier abotu how my car jsut died when i pressed on the brakes and all my dash lights and everythign dimmed, like my battery was complelty dead....well took it to autozone charged the battery put it back on and had them test out the alternator, well come to find out everything is GOOD.....so what can be cuasing my battery to die so fast? i turn off my radar detector now over night....i dont know what it could be? is there something grinding out?
please help
randy
Old May 10, 2004 | 05:36 AM
slopokrodrigez's Avatar
You have something draining the battery when the engine is off. My first guess is you have one of those big thumping amps. They do it everytime. If that's not it, remove one of the battery cables and put an amp meter in line with the battery and the cable you removed. There should be near 0 current draw. You will see in your case, some current draw. Now while you watch the meter, remove fuses one at a time until you find which circuit is responsible.
Also look over all the battery cables for spots rubbing the frame and be sure your battery is bolted down correctly.
Old May 10, 2004 | 06:09 AM
97FormulaWS-6's Avatar
I was going to say, a stereo can do it in a heartbeat, especially if they are not turning off completely, they're still drawing power.
I'm running a 200A power relay inline in my main power lead to my amps, completely disconnects the amps from the battery with the flick of a switch. It's saved my battery from dieing, I've left it on, and my battery WILL die in about a week.
Old May 10, 2004 | 10:03 AM
Jason Dove's Avatar
The stupid little light in the center console would drain my Optima in under 3 days if I didn't drive my car. The switch popped out of the holder, so the console lid being closed wouldn't turn the light off.
May 21, 2015 01:04 PM
Gtpguy
Jan 26, 2015 04:50 PM
Zomie
Sep 2, 2002 09:04 PM
slothgrant
Aug 22, 2002 03:01 PM
sleeperZ96BT
Aug 4, 2002 06:52 PM
