Those who have installed SVOs...
Old May 10, 2004 | 07:23 AM
pat97SS's Avatar
When inserting the injector into the fuel rail, the clip goes into the first (the most bottom) groove correct? When I did this they do not seem to be seated too deeply into the rail. The second groove does not run entirely around the injector so I can't see how you could clip it in there. I just want to be sure since we are dealing with gas. Thanks. By the way they are new 30# if that makes a diiference.
Old May 10, 2004 | 07:46 AM
pat97SS's Avatar
I did do a search and people have left the clips out entirely. I guess that the rail is bolted down. Anyone have any problems because they did not use the clips?
Old May 10, 2004 | 07:55 AM
Zepher's Avatar
I used the Clips on my 30# SVO's. They clipped on and seated fine.
Old May 10, 2004 | 09:44 AM
old93z's Avatar
Smile
i seated mine in the top groove. It seemed to go together fine.
Old May 10, 2004 | 10:31 AM
GetaZforgetGT's Avatar
I used the clips on mine as well.
I didn't like the way they looked either at first so I just put it together and bolted it all done. I tested for leaks by turning the switch on and letting the fuel pump prime the system.
If you don't get any leaks your in good shape.
Old May 10, 2004 | 10:36 AM
Chrisbequick's Avatar
No clips for over 3 years here with no problems.
-Chris
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
