Burnt wire.......now what?
Old Nov 19, 2003 | 05:36 PM
S.J.S.'s Avatar
K guys...as you al know got my stroker done and in. Everything is terrific, greater than I could have imagined. Took it out for the 4th time and it was missing. I found my #6 wire hitting the #2 header tube and was burnt just through the rubber barely seeing white. What kinda probs will I expect with that and can I just heat wrap it for now?????
These are brand new Taylors. I put them in while dropping in the motor and with the wires going behind the power steering pump, I'm sure its a biyatch to change out.
Whatcha guys recommendations on this?
Old Nov 19, 2003 | 06:02 PM
Heatmaker's Avatar
Advanced Member
I wouldn't trust a burnt Cylinder wire. It's better to just get a replacement. Are these Custom loomed or they the 50 dollar ones?
Old Nov 19, 2003 | 06:06 PM
S.J.S.'s Avatar
custom....but still the Taylors were like 47 bucks or so. but I was wondering for a temp fix what are my options?
CrockRocket94's Avatar
Replace the number 6 wire.. and put alot of heatwrap on it.. should take care of it.
Old Nov 19, 2003 | 06:57 PM
ibanez6rg's Avatar
Your best bet is to replace that wire. Blood, sweat, or tears... I don't care how hard it is, you nut
Old Nov 19, 2003 | 06:58 PM
Transamdriver's Avatar
Taylor makes replacement wires, it just a single wire in a pack with the proper hardware. I had to buy 3 after my header instal.
Old Nov 19, 2003 | 07:46 PM
S.J.S.'s Avatar
Whoa....Banester, a semi serious answer. Yeah I'm gonna replace it but for the next few days what?
Hey trans.....how did you replace yours??? any on the pass side? did you remove the power steering pump and all that or did you just reroute it?
Old Nov 19, 2003 | 08:08 PM
Your PM box is full, but the answer I tried to send to you was I only removed the Alternator and you just have to loosen the PS pump. Its easy to loosen the pump, its just 2 bolts.
Old Nov 19, 2003 | 08:14 PM
S.J.S.'s Avatar
PM box.....sent messages was full. I was like "wtf". Anyway, thanks. Yeah I remember the ps pump. Just put that **** in last week mon.
Thanks again. Hey what kind off loss would I see if I ran that wire like this. I won't but just curious. I pulled it back and seems to run fine. Slightly burn, lil through the red where I can see a touch of white insulation.
Old Nov 19, 2003 | 08:16 PM
Javier97Z28's Avatar
Moderator
Yep, I burnt one of mine too and ordered one of those kits from Thunder like a year ago. To this day I've not replaced it, one of my buddies lent me a stock GM wire and it's still in there.. have 7 Taylors and one GM wire lol.. I need to fix that
Old Nov 19, 2003 | 09:00 PM
ibanez6rg's Avatar
So it's not burnt all the way through? Not arcing at all? Yea, just wrap it up or whatever until you get that replacement. Keep it away from those primaries, they're hot, you dope
Old Nov 19, 2003 | 09:39 PM
S.J.S.'s Avatar
Thanks banester. Thats the answer I was looking for. No one really addressed the burnt wire, just replacing it. But hey don't get me wrong guys I appreciated all the info.
Thanks all.
blac94Z
Nov 4, 2015 01:59 PM
ZXXVIII
Sep 1, 2015 10:13 PM
dolfan324
Jul 17, 2015 10:34 PM
blkn'silver94
Mar 2, 2003 09:15 PM
blacknight
Jan 5, 2003 04:09 PM
