taking apart plugs again -- shoebox
Old Nov 18, 2003 | 11:43 PM
kevmor99's Avatar
I was able to take apart all of the plugs that have a clip on the rear of the plug that you take off, then you release each pin, but on the ones that have the big rubber piece you pull out of the back I can't seem to release the pins. I can see the rectangle that the pin would latch up against (see pic http://users.cwnet.com/~kevmor/plugs/PDRM0063.JPG). I stabbed it all over w/ a really small needle thing, whats wrong?
Old Nov 19, 2003 | 07:57 AM
You release the pin from the front, so that it will come out the back. There should be a small notch that you can get your tool into, if it is not a pin that you can use a barrel tool on.
Old Nov 19, 2003 | 08:58 PM
kevmor99's Avatar
Barrel tool? Is that one that goes around the whole pin? I tried pushing a paper clip (with a filed down tip) and i can push it into the notch in the front really far but it doesn't release...hmm. Do the pins look like the other ones I had in the pic (w/ the rubber plugs crimped on with the pins) do they have the same release clip?
Old Nov 19, 2003 | 09:42 PM
Yeah, the barrel tool would go around the whole pin, but some pins can't be released with that tool. Whatever pin you have, there has to be a small tab on it that is keeping it from pulling out the back.
greenzee28
Mar 26, 2015 09:13 AM
jasonduaine
Mar 7, 2015 09:44 AM
grabbem88
Feb 13, 2015 03:09 PM
Scottyboy
Feb 11, 2015 10:28 PM
Darth Xed
Jul 1, 2002 03:22 PM
