burning oil smell at wot
Old Jul 27, 2009 | 01:09 PM
onetransam4u2nv's Avatar
When i cruise around in my car everything is fine. When i stomp on it i can smell oil burning. I thought at first it was the common intake leak but apon inspection its bone dry. no wheres on this engine looks to have a leak. The only time you smell it is at wot. Any ideas are welcome
Old Jul 27, 2009 | 09:02 PM
96' Formula WS6's Avatar
Probably because your burning oil.
The best way to find an undetectable oil is to put the ultra violet dye is your oil, drive it around for a few days, then put a black light on it and that'll show you where your problem is originating.
Old Jul 27, 2009 | 10:18 PM
Any chance you are running a breather, in place of the vent line from the passenger valve cover to the throttle body? Might be venting a bit of excessive blowby at WOT.
Old Jul 29, 2009 | 12:44 PM
no there is no aftermarket breather thou i tried it to see if it fixed it. The motor is a cream puff it does not smoke nor drip any oil. I pulled this motor last year from a 96 z28 with 20,589 miles. When i pulled the intake this thing looked like it was never ran the valley was just a perfect gray not the burnt brown color. Maybe i just don't want to beleive it.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
surreybrad
Apr 22, 2015 06:40 AM
blkWidow
Apr 21, 2015 01:56 PM
blac94Z
Jan 12, 2015 05:44 PM
