burning oil... how much $
if you can do all the work from pulling the motor, taking the rotating assembly apart, installing the new rings (bearings to since your in there), putting it all back together, and re installing it in the car
your looking at about 400 to 500 bucks for everything
Depends on where the problem is. Is it coming out the tail pipe, or, does it just smell like oil when you walk around the car? I mean it could either be a internal engine problem, an intake manifold leak (real common), or just leaking from a valve cover. I am not up on prices of each, sorry.
Hal
Hal
I just found a possible solution. There is a hose going from the passenger side valve cover to the throttle body. At the valve cover, there seems to be a leak. Would the T.B. be sucking in oil from this hose and burning it to cause my smell/oil loss?
Achilles97
Sep 16, 2002 12:27 PM
