Bump starter.......
I'm confused...How do you bump the starter by hooking a switch from + battery voltage to ground? That's going to be one heck of a dead short.
A bump starter switch is connected where the two wires are connected to the solenoid. One is the purple wire, the other is the battery cable. You could hook to the battery or power junction up top, if you wanted.
ford
Aug 3, 2002 02:39 PM
