Bump starter.......
Old Jun 30, 2010 | 09:43 AM
jethrobodean's Avatar
Bump starter.......
Where do I hook up my bump starter on a lt1. I dont want to screw up and fry the PCM. Do I jump the terminals on the passenger fender?
Old Jun 30, 2010 | 10:39 AM
rclearyiii's Avatar
I use the positive terminal on the fender under the red cap and I use the alternator as ground. Never had a issue doing it that way.
Old Jun 30, 2010 | 03:56 PM
I'm confused...How do you bump the starter by hooking a switch from + battery voltage to ground? That's going to be one heck of a dead short.
A bump starter switch is connected where the two wires are connected to the solenoid. One is the purple wire, the other is the battery cable. You could hook to the battery or power junction up top, if you wanted.
Old Jun 30, 2010 | 04:13 PM
rclearyiii's Avatar
My bad..guess I thought he was referring to jump starting..LOL..
Jeff1904
Jun 5, 2016 05:00 PM
BLK1997Z28
May 2, 2015 01:26 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ford
Aug 3, 2002 02:39 PM
