Budget valvetrain for CC306?
Old Oct 23, 2005 | 07:11 AM
  #16
jkipp84's Avatar
Re: Budget valvetrain for CC306?
I don't know if you came across this or not, but for some general cam swap info, Shoebox put together a hell of a guide which includes parts, tools, etc here (#'s 6 & 7)
Old Oct 24, 2005 | 05:44 AM
  #17
BD380's Avatar
Can anyone else give me input on the parts list I posted? I need to know if I have everything that's needed.
Old Oct 24, 2005 | 08:42 AM
  #18
jsetzer's Avatar
Heres what I did:
New comp 612 springs (comes with locks/retainers)
new oem timing set
new factory hard push rods (n20 had mine a little.... bent)
used 30k mile oem lifters
used 1.6 crane golds self aligning
gasket kit from Combination Motorsports
That was the cheapest I found I could do it and have some reliability.
Stock bottom end, spinning to @ 6700. With longtubes, tune, 4.10s I am trapping consitent 108-109 on stock heads.
Old Nov 9, 2005 | 04:42 AM
  #19
BD380's Avatar
TTT
I need to know if I need 10* or 7* locks and retainers.
Old Nov 9, 2005 | 09:31 AM
  #20
97bowtie's Avatar
A 7 degree setup is a little stronger than a 10 degree lock/retainer.
Old Nov 9, 2005 | 09:36 AM
  #21
97bowtie's Avatar
Originally Posted by BD380
Ok, I've revised my list of parts. Does this look right? Anything that I need to change? Oh, and I have no clue whether to get 10* or 7* locks and retainers, so I just put 10* as a guess. Someone let me know if that's correct. Here's my list of parts, complete with part number, price, and vendor information. All these prices are the lowest I could find. Any input would be very helpful, considering I really don't know jack about valvetrain components.
[code]
Comp CC306 cam $245.95 CCA-07-306-8 Summit Racing
Comp 26918 beehive springs $159.99 63-26918-16 Thunder Racing
Comp spring locators $32.00 63-4705-16 Thunder Racing
Comp 11/32 10* lock set $19.76 CC-613-16 Combination Motorsports
Comp 10* steel retainers $49.95 63-795-16 Thunder Racing
Comp 1.6 non-SA rockers 7/16" $270.26 CC-1305-16 Combination Motorsports
Comp 7/16" rocker arm studs $29.95 63-4501-16 Thunder Racing
GM guideplates (8 needed) $26.32 20-14011051 Thunder Racing
Comp hardened pushrods $36.95 63-7808-16 Thunder Racing
LT4 extreme duty timing set $279.97 GM-12370835 Combination Motorsports
Oversize crank sprocket $40.00 68-S645 Thunder Racing
[/code]
Don't forget valve stem seals, intake manifold gaskets, waterpump gaskets and front cover gaskets. If you have high miles on the car, you might consider replacing the front cover seals as well. You can get all these from your local GM dealer.
You'll also want some engine assembly lube for the cam, however, you can also use oil to lube the cam if you will be starting the motor shortly after the cam is in. You'll also want a tube of black RTV to seal the front and back of the intake manifold and front cover.
Old Nov 9, 2005 | 01:42 PM
  #22
Hotwire's Avatar
I'd use grey RTV on the intake, cures harder and seals better.
Old Nov 9, 2005 | 02:42 PM
  #23
97bowtie's Avatar
I've never used grey, but used black on a number of cars with zero problems. Either will work.
Old Nov 9, 2005 | 03:44 PM
  #24
hsyr's Avatar
Never noticed if you said it but do you have the supporting boltons to go with the cam? I don't know if there is many but I do know that you will need atleast a mail order tune and some headers. I wouldn't run stock manifolds with that cam.
Old Nov 9, 2005 | 04:04 PM
  #25
jasons93z's Avatar
what about lifters?
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
Z Power
Sep 19, 2015 11:19 PM
MDZ28
Sep 7, 2015 09:16 PM
NewsBot
Aug 21, 2015 07:20 PM
