Budget minded 383
Old Sep 16, 2008 | 11:52 AM
  #16
blue 79 Z/28's Avatar
if it were me on a budget, id get a scat 9000 cast steel crank and use that savings and focus on the weight on the crank aka rods and pistons. a scat pro comp i beam in 6" form and a light set of forged mahle or comparable pistons will be way better off then the lead weight hyper pistons and a 5.7 rod. there will be less strain on the crank and rod throughout the rpm range and will be truly bulletproof with the right parts selection. a sbc crank is not a weak link, they are a pretty strong design, the forces on it at 6500rpm; a few grams off will feel like a few hundred pounds less to the crank when its revved.
Old Sep 16, 2008 | 12:40 PM
  #17
Gripenfelter's Avatar
Originally Posted by GreasyB
Well I had a thrust bearing go out in my engine. I am suspecting I atleast need a new crank anyways. Well I was thinking about doing a stroker kit while I was at it. The engine is already 30 over. I am just assuming that it may need bored again. I dont know exactly what kit or what individual parts I need to get. Also I want to keep clearancing to a minimum. If you guys have part #'s and costs of your set ups that would be greatly appreciated. Any advice on doing this would help out tons too.
If you are going to spend money anywhere, spend it on the crank and heads.
I went with a Callies Dragonslayer crank and LE2 heads.
Then just SRP pistons and Eagle rods.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
Ks0209
Oct 1, 2015 07:32 AM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
