Broken dipstick in oil pan
Old Feb 9, 2009 | 12:46 PM
1994greenz28's Avatar
The bottom of my oil dipstick is broken off inside the oil pan. I check my oil yesterday and when I pulled the dipstick, it was missing about 1in from the bottom. It looked like it just snapped off. Will the piece just float around in the oil pan or can it get stuck somewhere and block oil passages? I will probably have to pull the oil pan to get it out (I just replaced the gasket 8 months ago!!) Oh well, it will give me a reason the do the opti oil seal.
Old Feb 9, 2009 | 03:06 PM
Jlo's Avatar
Jlo
I hate when that happens. Use a reverse tap to get it out make sure it's the size of the dipstick hole and it should come right off...Trust me I know from experience.
Old Feb 9, 2009 | 06:30 PM
I am talking about the piece you pull out to check the oil level. Not the actual tube. It is the flat piece of metal.
Old Feb 9, 2009 | 07:34 PM
Stl94LT1's Avatar
I would get it out, whatever it takes. Try draining the oil and using a telescopic magnet in the drain hole. If that doesn't work, I would pull the pan.
Old Feb 9, 2009 | 09:52 PM
user 647483's Avatar
Just make sure the magnet doesn't get stuck LOL
Pull the dipstick tube out of necessary, you should be able to fish the
peice out if it didn't get lodged somewhere. You don't want that thing to
get into the bearings and tear them up.
I can just see someone put a big magnet on the pan and leave it there,
hoping the chunk just sticks to the bottom until they rebuild it someday.
Old Feb 10, 2009 | 08:52 PM
rskrause's Avatar
Moderator
You need to get it out!
Rich
Old Feb 11, 2009 | 11:42 AM
green.Z's Avatar
I had the same thing happen to me from when I bent it around too much when I installed my headers. I've been driving it with it in the pan now for about 40K miles. Maybe I got lucky, but it's been no problem.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
