Broke a sensor during LT installation
Old May 7, 2006 | 03:36 PM
gbu27's Avatar
Me and my buddy started working on my new exhaust this weekend. When we started pulling off the driver side manifold we broke a sensor on the side of the driver head. We are thinking maybe a coolant sensor or something but arent really sure. If anyone knows what its proper name is or maybe has a diagram and could post it that would be much help. thanks
Old May 7, 2006 | 03:38 PM
Stoopalini's Avatar
Re: Broke a sensor during LT installation
Yep, that's the sensor which feeds the dash gauge. They're under $20 at a local autoparts store. Make sure you bring it with you, as they'll list two coolant sensors/sending units. One is the one you broke, and the other is in the water pump (it feeds the PCM the coolant temp).
Thomas.
Old May 7, 2006 | 03:42 PM
luckyou03's Avatar
broke mine to when i installed my long tubes by myself. have the new sensor ready when you take the old one out, because tons of coolant is going to pour out.
Old May 7, 2006 | 03:45 PM
dochidalgo's Avatar
Could be the engine temp gauge sensor?....See the pic in the link, please..
http://shbox.com/1/temp_sensor2.jpg
Thanks to Rob Shoebox for the picture
Dochidalgo
Old May 7, 2006 | 03:51 PM
wrd1972's Avatar
Yup I did it to. Its the coolant sensor for the temp gauge.
Easy fix.
Old May 7, 2006 | 05:58 PM
gbu27's Avatar
yup that would be it thanks
Old May 8, 2006 | 08:12 PM
gbu27's Avatar
hrmm guess i picked up the wrong one, the sensor i got looks just like the one i broke off, but the pin setup is different.The title on the one i got says temperature coolant sensor, so i guess im needing one that specifically mentions temp GAUGE sensor?
Old May 8, 2006 | 10:04 PM
Stoopalini's Avatar
Ask them to look up a "Sending Unit" instead of sensor, and you should get the right one.
Thomas.
Old May 9, 2006 | 09:30 AM
matt65's Avatar
I did the same thing during my install.
Old May 9, 2006 | 04:08 PM
2000GTP's Avatar
Me too, even after reading everyones warnings.
Old May 9, 2006 | 07:08 PM
JoeliusZ28's Avatar
ill remember to be careful with that one in a few weeks when i do mine
Old May 9, 2006 | 07:28 PM
1SlowFormula's Avatar
^^^ me too...
sscott
Jan 17, 2015 04:30 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
slothgrant
Aug 22, 2002 03:01 PM
