Breather Cap on valve cover?
Old Jul 22, 2006 | 08:57 PM
  #31
1racerdude's Avatar
Re: Breather Cap on valve cover?
Originally Posted by flusz28
so the check valve goes inside the hose on the driverside of the intake?
Between the PCV valve and the vacuum supply fitting.
Old Jul 22, 2006 | 09:10 PM
  #32
1racerdude's Avatar
The check is installed to prevent boost from entering the vacuum hose.
It will be a one way check so blow or suck on it to find out which way.
OK get ya mind out of the gutter.
Old Jul 22, 2006 | 09:52 PM
  #33
flusz28's Avatar
alright cool thanks for the info and heads up..
Old Jul 22, 2006 | 10:34 PM
  #34
thesoundandthefury's Avatar
I know this may sound overly simplistic, but for the guys who are experiencing the problem of having oil sucked into their intakes, would it be possible to install an inline check valve into the hose that runs from the throttle body to the valve cover? (So that air may flow FROM the throttle body to the valve cover, but nothing may flow BACK in the opposite direction?)
Old Jul 24, 2006 | 11:15 AM
  #35
The system was intentionally designed by GM for the vent line to reverse flow in cases where the crankcase pressure exceded the capacity of the PCV system. If you block the vent line with a check valve, you run the risk of the crankcase pressure building up and blowing the dipstick out of the tube, or causing oil leaks at seals.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Jan 30, 2015 11:34 PM
Jul 4, 2005 05:00 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
