Bosch Iridium Fusion?? / Car runing rich...
Old Oct 2, 2007 | 06:03 PM
ussj4brolli's Avatar
Hi. I was just messing around with my car (94 Z28 Camaro) and recorded a
tts data log. At 75MPH my
Fuel trim cell is 7
LTerm Counts 108(r)/108(r) @75mph....no noticable fluxuation
Sterm Counts 121(r)/122(r) and they fluxuate 121(r)/132(g) 131/133 130/132 all @75mph
(r)=red (g)=green
At idle the
LTerm is 111(r)/108(r)
STerm fluxuates 129(w)/126(w) 127(w)/124(r) seems the 2nd number is always white or red at idle...could this be a bad bosch O2? (2 months old) and would the plugs im running, the Bosch Iridium Fusion(4 arc) make it run rich for some reason? I will produce the datamaster file later today when im not at work.
Thinmgs that have been changed in the last 4 months. Injectors (from my 95 Z28), Coil, plugs, TPS, Knock sencer, MAF(from 95Z28), MSD cap/rotor, Both O2s, PCV...and i think some more that I cant think of....any suggestions?
I want to get the MSD6a, Blaster coil, and 8.5MM plugs here soon too.
Last edited by ussj4brolli; Oct 3, 2007 at 05:47 PM. Reason: Edit, idel fuel trim is 16
Old Oct 3, 2007 | 05:38 PM
If parts were moved from your old 95 LT1, what year car are you putting them on now?
Old Oct 3, 2007 | 05:47 PM
oops..forgot to mention that. The car is a 94 Z28 Maro.
USAirman93
Nov 24, 2014 03:37 PM
CobraEatr
Jul 24, 2004 11:37 AM
94z28jbw
Sep 8, 2002 03:22 PM
Burn_Out
Aug 18, 2002 08:49 AM
CobraEatr
Jul 29, 2002 11:46 AM
