Blue Stripe Beehive Springs
Old Nov 28, 2007 | 06:44 AM
maverickmk's Avatar
OK, I've done a search and can't find any specifics regarding the proper valve springs I should use for the LT1 motor I'm building. I have a friend that has a set of new Comp Cams springs with a blue stripe on them. (don't know their part number) I thought I once heard to stay away from the blue stripe springs (?) Anyone know why? If I should avoid these what springs should I buy. I have purchased a Comp Cams 503 cam and 1.6 Pro Mag rockers.
Old Nov 28, 2007 | 08:24 AM
wrd1972's Avatar
http://www.cz28.com/forums/showthrea...&highlight=918
If you want to play it safe avoid blue stripe beehives like the plague, they may be the good ones or they might be the ones that break.
The new beehives dont have the strip I think.
Old Nov 28, 2007 | 09:49 AM
maverickmk's Avatar
Any chance Comp will replace them?
Old Nov 28, 2007 | 10:50 AM
1989TransAm's Avatar
You can find out with a phone call to Comp.
Old Nov 28, 2007 | 11:03 AM
SStrokerAce's Avatar
Or just go with the PAC 1218's
Old Nov 28, 2007 | 11:11 AM
Vicious95Z28's Avatar
Yeah, I'd take Bret's advice on this one.
Old Nov 28, 2007 | 11:16 AM
maverickmk's Avatar
Forgive me for being a moron - but what are PAC 1218's? Who makes them? I can probably get them from Summit or Jegs, correct? Again, sorry for being an idiot about this. Thanks for all the help.
Old Nov 28, 2007 | 11:36 AM
No Summit and Jegs don't sell them... only dealers or straight thru PAC.
Long story short..... up till 2006 PAC (Petersen Spring) made all the springs for Comp Cams, including the 26918 beehive. From 2006 on is when Comp had problems with the 918 springs because they changed suppliers. They are the actual company that makes the springs, not just another company who retails them.
Bret
Old Nov 28, 2007 | 12:15 PM
speed_demon24's Avatar
Maybe, give them a call.
Here's what the new 918's look like. My dad's going to run them in his LS1 car when he puts a cam in it.
http://i86.photobucket.com/albums/k1...g?t=1196275022
http://i86.photobucket.com/albums/k1...g?t=1196274993
http://i86.photobucket.com/albums/k1...g?t=1196274946
Old Nov 28, 2007 | 03:30 PM
cvccbum's Avatar
Yep. I got a set of blue stripe 918's and emailed comp cams.
They sent me replacement springs overnight, and i shipped mine back. The new ones look like the ones speed_demon24 posted.
Old Nov 28, 2007 | 04:53 PM
maverickmk's Avatar
Awesome - I'll give it a try. Thanks.
Old Nov 28, 2007 | 08:48 PM
elisowski's Avatar
What's the main problem? Is it breakage only, or do they get weak and lose their seat pressure?
Old Nov 28, 2007 | 09:46 PM
Kevin Blown 95 TA's Avatar
They were breaking.
Old Nov 28, 2007 | 09:48 PM
mdacton's Avatar
Shon heron a supporting vendor had a deal going on with them, he will hook you up.
Old Nov 29, 2007 | 12:00 AM
97SS0594's Avatar
i found a link on LS1tech that had thad the code for the bad springs. i have blue striped springs in my Z28 and my SS and havent had a problem.
