blows oil when you let off the gas?
Old Apr 20, 2004 | 10:16 AM
Hotwire's Avatar
when they'd let off the gas, the motor would start winding down w/ the dyno, but it would blow a puff of blue smoke right after wot-0 throttle. I know it's burning oil, but what would cause this??
Old Apr 20, 2004 | 10:43 AM
Could be sucking oil down the valve guides. Maybe some new valve seals are in order.
When the engine is winding down from high rpms and closed throttle, vacuum is at it's highest.
Old Apr 20, 2004 | 12:18 PM
Hotwire's Avatar
thanks rob, can you think of anything else? heads were new.. well, think he had about 2-4k on them.
Intake gasket leak? wouldn't that show up at idle? think it would hurt the #s that bad?
Old Apr 20, 2004 | 12:22 PM
WS Sick's Avatar
When you drop the throttle blad there is high pressure there, but not in the crank case, so any weakness (such as the breather tube to the pass valvecover) will suck in crankcase air. Usually its the breather, but rings could cause this, but if it only does it then there is nothing to worry about.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rideordie
Nov 5, 2019 04:52 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
simple
Aug 11, 2002 11:56 AM
