Water pump driver shaft o rings ?
Old Apr 20, 2004 | 12:02 PM
Warren_Seale's Avatar
Are the front (water pump side) and the rear (timing chain side) o- rings of the water pump drive shaft the same? The pump appears to have one already on its splined input shaft. Is that one of them?
Warren
96 T/A,WS6,M6
79 T/A,WS6,A3,403
72 442,W30,A3
Old Apr 20, 2004 | 12:42 PM
Would you like to read the answer here or on the f-body message board/
Your observations are correct.
If you need p/n:
1993-1997 water pump drive shaft o-ring 12553792
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
