blown head gaskets
Old Aug 11, 2004 | 04:37 PM
Trmpt63529's Avatar
blown head gaskets
are lt1 heads bad about warping? i've got two blown head gaskets, and praying they didn't warp...
Old Aug 11, 2004 | 04:38 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: blown head gaskets
if you blew a head gasket, the heads are probably warped. not a big deal, they can be resurfaced, but even if they can't be.. new set wont set ya back more than $150-200.
Old Aug 12, 2004 | 01:27 AM
Lt1t56's Avatar
I did my head gaskets on my Z in April and wondering when the T/A is going to blow. When I did the Z I took the heads to the machine shop and they were warped slightly, had them totally reworked. Also just finished doing my nephews 93 3.8 V6 T-bird head gaskets and those heads were warped as well. My opinion..... if they are aluminum heads and a head gasket fails, they are warped. Its definately worth the machine shop charges and its also piece of mind knowing that you are going through all that trouble to repair car and you are putting good set of heads on.
Old Aug 12, 2004 | 02:55 AM
97WS6SCharged's Avatar
It's always a good idea to have the heads checked when they're off the car whether they are iron or aluminum.
Old Aug 12, 2004 | 06:57 AM
94_Z28_guy's Avatar
Its not much $ to get them re-plained. I did/would.
Old Aug 12, 2004 | 12:45 PM
rskrause's Avatar
Moderator
Originally Posted by 2CNTRY
How much does it typically cost to replain?
Milling the head flat should be ~$30/head unless they are badly warped.
Rich
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
