Blocks to avoid?
Old Apr 8, 2012 | 02:01 PM
jloshotz's Avatar
Blocks to avoid?
Hey all, I'm currently weighing my options on replacing the motor in my '95, are there any castings to avoid, road master, impala, caprice etc? I'm hoping to find a reasonably priced, stockish short block/long block that I will be able to just bolt everything on my current motor to, and just want to avoid problem areas. Any advice, input would be appreciated. Thanks!
Old Apr 8, 2012 | 04:49 PM
Re: Blocks to avoid?
All LT1 blocks are identical, except the Corvette blocks and factory "replacement" blocks. The last two have 4-bolt mains rather than the 2-bolt mains used in all the other cars. An LT1 block will have the numbers 327 on it. That's the last three digits of the casting number.
Avoid what looks like an LT1 block, but has "4.3" cast in it.... that's an L99 265ci block.
Old Apr 8, 2012 | 05:09 PM
jloshotz's Avatar
Thanks Fred, good to know about the 4.3 casting. I recently lost a wrist pin bearing and am seriously considering doing a stock ground up rebuild on the engine. So....I may be just redoing my own block, still undecided. I might upgrade the cam, (just slightly) but aside from that I'm going to go all stock internally with the exception of LT4 stock ratio rockers, which I already have. Any recommendations on a cam? The car will be driven a bit, so I'd like to stay somewhat conservative. Thanks!
Old Apr 10, 2012 | 02:44 AM
blue 79 Z/28's Avatar
so basically a cam only car? here are some cam combos
Advanced Induction - Ai System LT1 Cam Kits
Old Apr 10, 2012 | 10:20 PM
jloshotz's Avatar
Thanks blue!
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
