is this block rebuildable?
Old Apr 9, 2012 | 07:43 PM
don's Avatar
don
hydro locked engine with two broken rods that broke a chunk out of the bottom of the cylinder about half inch square look at the pic and see what you think. lt1 block
DSC07560 | Flickr - Photo Sharing!
Old Apr 9, 2012 | 08:19 PM
bw_hunter's Avatar
Re: is this block rebuildable?
Boy, I don't think so. You'll have to grind away any stress risers and I think it'll be to far into the cylinder for that. Maybe MachinistOne can chime in.
I don't know if it can be done or not but a sleeve might get you back in business.
I'd start the search for another block. You can use anything out of a f-body, b-body or y-body unless it has 4.3 cast into the side..All the other blocks have 327 cast into them.a casting number, not a displacement...
God luck!
Old Apr 10, 2012 | 02:28 AM
blue 79 Z/28's Avatar
no good depending on the type of build (if you hold a high standard then no way). if its a stocker build then you could grind and chamfer, but the piston skirt will wear a groove eventually. a sleeve would work but waste of money by the time you sonic check the block for cracks and do all the machine work, just find another block. its not like its a dart race block.
Old Apr 10, 2012 | 05:43 AM
RamAir95TA's Avatar
For your own peace of mind and the relatively low cost of finding a good condition used block the choice to me is obvious.
Old Apr 10, 2012 | 08:43 AM
Bersaglieri's Avatar
This.
-Dustin-
Old Apr 10, 2012 | 08:21 PM
MachinistOne's Avatar
Yeah, that's repairable as long as it's not cracked. Issue is that you'll distort the accompanying cylinders with the sleeve install so you'll be going to the next oversize on the whole block to do it right.
Not sure what the going rate is on a replacement block right now, I would imagine pretty cheap - we haven't done one in quite a while because there's no demand.
Old Apr 11, 2012 | 09:22 AM
don's Avatar
don
thanks, that is what i thought, not worth the risk.
jer4251
Sep 21, 2020 09:42 PM
Sergio
Jan 27, 2016 04:27 PM
surreybrad
Apr 22, 2015 06:40 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
