block and crank from bad machine shop
Old Mar 3, 2015 | 02:02 PM
maybe2fast's Avatar
Thoughts or feelings? seems they messed it up badly
Chevy GM LT1 block (4 bolt main) bored +.030 for 383 stroker ESP Crank
Old Mar 3, 2015 | 07:43 PM
8cylinders>4's Avatar
Re: block and crank from bad machine shop
I would think the block is salvageable. There is always a risk of hitting water on these blocks clearancing for strokers. 3.75 stroke is less common however usually its the longer strokes guys run into problems with.
People dedicating a motor for track duty or light road duty would partially fill the block and be done with it.
You couldn't pay me to use the crank though, eagle cast cranks, especially the older ones had quality issues as it was. they're weaker than the stock crank as well. That and they cracked it. Its a paper weight in my opinion.
Old Mar 4, 2015 | 09:14 AM
maybe2fast's Avatar
Yeah, I have seen this for sale for quite some time and finally made this post about it. I was thinking the same about the block being savable.
Old Mar 5, 2015 | 03:47 PM
97 6SPEED Z's Avatar
Question Re: block and crank from bad machine shop
Maybe2fast, you have me a bit confused about this block? Is this your block that you are looking to sell, or someone else's block? Is this block located in the metro Detroit area, or somewhere else? Finally, if this is your block, do you know if its been decked, and what its been decked too?
TIA for any additional info.
Old Mar 6, 2015 | 06:39 AM
maybe2fast's Avatar
This is NOT mine. I have been seeing it on Craigslist and wanted some thoughts on it. Thats all
Old Mar 13, 2015 | 12:44 AM
MachinistOne's Avatar
Run away.
Old Mar 13, 2015 | 11:48 AM
bw_hunter's Avatar
Originally Posted by MachinistOne
Run away.
I was waiting for this post...
Scottyboy
Feb 11, 2015 10:28 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
chuyz28
Nov 25, 2014 11:14 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
1LEThumper
Jul 14, 2003 12:45 PM
