block and crank from bad machine shop
Thoughts or feelings? seems they messed it up badly
Chevy GM LT1 block (4 bolt main) bored +.030 for 383 stroker ESP Crank
Re: block and crank from bad machine shop
I would think the block is salvageable. There is always a risk of hitting water on these blocks clearancing for strokers. 3.75 stroke is less common however usually its the longer strokes guys run into problems with.
People dedicating a motor for track duty or light road duty would partially fill the block and be done with it.
You couldn't pay me to use the crank though, eagle cast cranks, especially the older ones had quality issues as it was. they're weaker than the stock crank as well. That and they cracked it. Its a paper weight in my opinion.
Yeah, I have seen this for sale for quite some time and finally made this post about it. I was thinking the same about the block being savable.
TIA for any additional info.
1LEThumper
Jul 14, 2003 12:45 PM
