Bleeder Screw Question
I dug into the parts book for you.
GM PART # 10070107 for the bleeder.
Sorry if I confused you. The screw that has the flat head screwdriver top broke off in that valve. I was wondering if I have to replace the whole hose assembly, or I can just remove the valve via the hex bottom and swap out the screws.
Very simple fix.
To add to this topic I also have problems with the bleeder on my thermo housing. It is was really stuck in there after the part sat dry on the shelf for a year or so. I wound up stripping the actual fitting including the hex. The metal is really soft because it is brass. I wound up drilling it out with a drill press, and tapping the aluminium to a new size. From there I went to orielly auto parts and got a radiator petcock valve. LOL It is the t handle style valve that is hollow in the center, and has a hex to thread into part. Hope this works for me. I figure the valve will hold pressure fine, because it is made for coolant system.
Chris Anderson
Jan 27, 2015 08:30 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
squarehead
Nov 21, 2014 08:02 PM
