Bleeder Screw Question
Old Jul 30, 2009 | 03:53 PM
  #16
Originally Posted by LsX iN fOx
These cars are rare by me unfortunetely =(
It does not have to be off an f-body or even an LT1. Bleeders were used on lots of vehicles.
Old Jul 30, 2009 | 08:24 PM
  #17
LsX iN fOx's Avatar
this is true I never thought about that. Wonder if the parts store sells the valve alone or I gotta buy the whole heater hose assembly
Old Jul 30, 2009 | 11:14 PM
  #18
I'm not sure you are getting it (or I don't understand what you need). You only need the tiny little bleeder - not any pipe or hoses.
I dug into the parts book for you.
GM PART # 10070107 for the bleeder.
Old Jul 31, 2009 | 07:26 PM
  #19
LsX iN fOx's Avatar
Sorry if I confused you. The screw that has the flat head screwdriver top broke off in that valve. I was wondering if I have to replace the whole hose assembly, or I can just remove the valve via the hex bottom and swap out the screws.
Old Jul 31, 2009 | 10:36 PM
  #20
That is what I have been trying to tell you to do since this thread started. Very simple fix.
Old Aug 1, 2009 | 05:50 PM
  #21
LsX iN fOx's Avatar
haha sorry man Im a mess. Thing has been busting my chops since I got it. Just wanna drive the damn thing lol
Old Aug 2, 2009 | 04:00 PM
  #22
ascastil's Avatar
I went to the junk yard and got mine, GM used them on the 3.4 and 3.8 liters too, like the Malibus and Impala, pretty sure it was one of those models that i pulled it off of.
Old Sep 27, 2009 | 05:06 PM
  #23
Dave1980's Avatar
To add to this topic I also have problems with the bleeder on my thermo housing. It is was really stuck in there after the part sat dry on the shelf for a year or so. I wound up stripping the actual fitting including the hex. The metal is really soft because it is brass. I wound up drilling it out with a drill press, and tapping the aluminium to a new size. From there I went to orielly auto parts and got a radiator petcock valve. LOL It is the t handle style valve that is hollow in the center, and has a hex to thread into part. Hope this works for me. I figure the valve will hold pressure fine, because it is made for coolant system.
grgguy
17
Feb 23, 2015 07:57 PM
Chris Anderson
Jan 27, 2015 08:30 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
squarehead
Nov 21, 2014 08:02 PM
