Bleed cooling system?
Old Apr 20, 2008 | 02:18 PM
BlackHawk23's Avatar
Does anyone know if you need to bleed the cooling system after a drain and refill? Whats the best way to do this?
Old Apr 20, 2008 | 02:20 PM
2000GTP's Avatar
Shoebox has all the info you need: http://shbox.com/1/bleeders.jpg
Old Apr 20, 2008 | 02:25 PM
bleed coolant system
Nice, thanks. Do i just let it warm up, and crack the bleeders to let the air out, or should i open them while its running? The lower hose is building up alot of pressure, but the car is at operating temp. Not sure the best way to do this.
Old Apr 20, 2008 | 02:37 PM
Pontiac_97's Avatar
run the engine for a few minutes and crack open the screw for a few seconds close it for 10-15 seconds. repeat until you have a steady stream of coolant and no bubbles
Old Apr 20, 2008 | 02:43 PM
Nice, ill give it a try. Thanks alot!
Magenta_Hearts
Mar 25, 2015 10:24 AM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
