need info on comp cams 502 grind
Old Oct 26, 2004 | 11:39 AM
1_bad t/a's Avatar
just as the title says, going to install it soon. Just wanted to know the gains i will get with this cam.
Old Dec 15, 2006 | 07:05 PM
Wild1's Avatar
What do you think of the cam? Did you install?
If so, what did the dyno say?
Old Dec 16, 2006 | 09:16 AM
1_bad t/a's Avatar
well its a very streetable cam, haven't tuned it yet , for that same reason that the ecu does freak out or anything. My best time is in the sig, consistant 12.6's.
Old Dec 16, 2006 | 02:25 PM
87lt1rx7's Avatar
I am pretty impressed with your best e.t i have yet to get my engine in but should be in within the next few weeks. are you on stock heads? hopefulyl the fact i have le1 heads can get me a little lower. i don't know what what i would do with a 12.40 e.t
Old Dec 16, 2006 | 07:25 PM
1_bad t/a's Avatar
thats my best, but don't get me wrong i've hit it 12.49's like 6 times already, but thats the best its done as far as heads there stock.I remember when i wanted heads for my lt1 ,loyd told me that i would be in the low 12's w/ the tuning.but i haven't tuned because i'm building a 385ci w/ le2 heads, le4 cam . thats the reason i haven't done anything 2 this set up.
Old Dec 17, 2006 | 01:02 PM
Wild1's Avatar
That is a great time with stock heads!
Old Dec 17, 2006 | 06:24 PM
1_bad t/a's Avatar
thanks bro
Old Dec 17, 2006 | 07:58 PM
jasonisdn's Avatar
whats the specs on the 502? we had guys running 4:10's, small nitrous cam (no nitrous used on this example),headers, M6, CAI running 12.2's about 10 years ago. i mean that was a small cam. i think i have 1 video of 1 of those cars making a pass with that setup.
Old Dec 17, 2006 | 08:21 PM
1_bad t/a's Avatar
the spec r 218/ 224 .495/ .503 on 112lsa if i'm not mistaken. as far as mine is an auto, and it got 3.42 gears.Maybe w/ that and tuning i can hit those #'s
Old Apr 20, 2008 | 03:01 PM
87lt1rx7's Avatar
just an update on this cam in case anyone is looking around. I ran a 13.1 @109.64 with a 2.2 60'. this cam can be a mid 12's cam for me if i can learn to launch my car
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
