Bleed cooling system?
Shoebox has all the info you need: http://shbox.com/1/bleeders.jpg
bleed coolant system
Nice, thanks. Do i just let it warm up, and crack the bleeders to let the air out, or should i open them while its running? The lower hose is building up alot of pressure, but the car is at operating temp. Not sure the best way to do this.
Magenta_Hearts
Mar 25, 2015 10:24 AM
