The BIGGER Oil Filter!
ok i went to a couple of places today and heres what i have found
theres the
Mobil 1 M1-302 seems to be the bigger size from the stock m1-202
then theres a PF-35L which seems to be the bigger one from the STOCK PF25
but theres also the PF-1218? which also seems like it would work as well..
anyone care to comment on this
theres the
I tried the PF-35L on my 97 and it appeared to be the lowest point on the car so I did not want to use it. Used an STP filter that time. Found a parts house that had a case of the correct AC filter for the LT-1 and bought the whole case. Wont have a problem until I run out. The Mobil -1 filter is a bit on the expensive side. I suppose that if I read a good enough tech article on it that it may be worth it. Thanks
I use the Fram HP4 (its in a silver box, cuz its special)
its a 1 qt filter, I always fill it with a full qt of mobil one before installing it. I dont want the motor running dry for 3 seconds (mabye 4 or 5 with a filter like that). I have a 9qt system now but I think 5 qts still put it to the full mark. with the 1 qt filter on a stock oiling system
did u put a big block in you car or something
how the hell did u come up with that figure? are u just running a really deep pan or what?
Bigger is definitely better here, it'll flow more oil and also increase your oil capacity slightly (which puts less stress on the oil)
I use the K&N HP3002, which is the PF1218 equivalent. These filters have an antidrainback valve, while the PF35 does not.
I started using longer filters on an LT1 back in 1996, when I had my 95 Trans Am. Back then I used the PF35L.
There are no drawbacks to using the longer filter here, IMO it's not in danger of getting hit by debris by any means.
i use the stock filter i cant remember the model i think its pf 58 or something. i want to use the bigger filter thats just like it, just taller and holds more oil is that the pf 1218 you are talking about?
