The BIGGER Oil Filter!
Old Aug 12, 2003 | 06:57 PM
InjectedSS's Avatar
ok i went to a couple of places today and heres what i have found
theres the
Mobil 1 M1-302 seems to be the bigger size from the stock m1-202
then theres a PF-35L which seems to be the bigger one from the STOCK PF25
but theres also the PF-1218? which also seems like it would work as well..
anyone care to comment on this
Old Aug 12, 2003 | 07:25 PM
Royce Friesen's Avatar
I tried the PF-35L on my 97 and it appeared to be the lowest point on the car so I did not want to use it. Used an STP filter that time. Found a parts house that had a case of the correct AC filter for the LT-1 and bought the whole case. Wont have a problem until I run out. The Mobil -1 filter is a bit on the expensive side. I suppose that if I read a good enough tech article on it that it may be worth it. Thanks
Old Aug 12, 2003 | 07:29 PM
RCF925's Avatar
I've been running the longer one for years with no problems, My personal choice is the Baldwin B6 filter
Old Aug 12, 2003 | 07:32 PM
InjectedSS's Avatar
whats the over all benefits?? i guess just MORE filtration?? also are you guys adding a lil more oil to your engine since the filter is bigger?
Old Aug 12, 2003 | 08:28 PM
The 1218 is the replacement for the 35. They probably have not run out of stock yet.
Old Aug 12, 2003 | 08:43 PM
Dave Feerst's Avatar
I use the Fram HP4 (its in a silver box, cuz its special)
its a 1 qt filter, I always fill it with a full qt of mobil one before installing it. I dont want the motor running dry for 3 seconds (mabye 4 or 5 with a filter like that). I have a 9qt system now but I think 5 qts still put it to the full mark. with the 1 qt filter on a stock oiling system
Old Aug 12, 2003 | 10:52 PM
InjectedSS's Avatar
whoa whoa wtf? 9 QUARTS did u put a big block in you car or something how the hell did u come up with that figure? are u just running a really deep pan or what?
Old Aug 12, 2003 | 11:03 PM
kgkern01's Avatar
I use the PF 1218.
Old Aug 12, 2003 | 11:28 PM
InjectedSS's Avatar
how much extra oil are u guys using? like 1/2 qt?
Old Aug 12, 2003 | 11:34 PM
96z's Avatar
96z
I use the PF1218 too....
Old Aug 13, 2003 | 05:24 AM
Patman's Avatar
Bigger is definitely better here, it'll flow more oil and also increase your oil capacity slightly (which puts less stress on the oil)
I use the K&N HP3002, which is the PF1218 equivalent. These filters have an antidrainback valve, while the PF35 does not.
I started using longer filters on an LT1 back in 1996, when I had my 95 Trans Am. Back then I used the PF35L.
There are no drawbacks to using the longer filter here, IMO it's not in danger of getting hit by debris by any means.
Old Aug 13, 2003 | 05:27 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Old Aug 13, 2003 | 07:48 AM
EaC95Z28's Avatar
i use the stock filter i cant remember the model i think its pf 58 or something. i want to use the bigger filter thats just like it, just taller and holds more oil is that the pf 1218 you are talking about?
Old Aug 13, 2003 | 08:40 AM
darkangel95's Avatar
I am using a NAPA Gold 1061. Now I have an extra 1/2 quart of oil, I assume that it is basically the same size as all of the other filters mentioned.
Old Aug 13, 2003 | 02:20 PM
InjectedSS's Avatar
are u running a stock pan? if so what would you say your TOTAL oil capacity is now?
