Big Job (need some oil pan advice)
Old Apr 17, 2011 | 01:18 AM
Nossem's Avatar
So I started a big project on a 94 Camaro Z28 Lt1 engine. The clutch was slipping after 3k RPM. So i decided to upgrade to a stage 2 clutch. Took the tranny out the car, bought a new flywheel, and decided to fix a newly discovered leak on rear main seal. Problem was the oil pan seal came out with it, so now i have to replace that seal, seems like the only way to fully take off the oil pan is to lift the engine... I dont want to do that. I was thinking of cutting the seal and putting it in that way and basically hoping it wont leak. what do you guys think?
Old Apr 17, 2011 | 08:59 AM
Re: Big Job (need some oil pan advice)
"Drivetrain" is primarily for tranny and rear axle questions. Let's move this to "LT1 Based Engine Tech".
Old Apr 17, 2011 | 10:00 AM
Nossem's Avatar
Nevermind I got it out. a future thanks tho to whoever was going to reply.
jer4251
Sep 21, 2020 09:42 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
