BIG cubed LT1 + solid roller cam = Knock sensor go crazy?
Old Jun 3, 2003 | 10:07 AM
LT1 S-10's Avatar
A little bit of an issue we need to address:
This is a big cubed LT1 with a solid roller .700+ lift cam. We are expecting 10.60's n/a.
What kind of knock sensor problems are we going to run into? I believe the car is being converted to the LT4 style knock sensor and module. Is this motor going go cause too many vibrations setting off the knock sensor?
Any insight from you fast guys/LT1 gurus out there on this is greatly appreciated.
Old Jun 3, 2003 | 10:48 AM
97Z-M6's Avatar
you need to purchase lt1 edit and you can desencitize the knock sensor in the programing enough to not mess with performance but let you know if something is wrong.
i take that back you need to go to some one that knows what there doing when it comes to the pcm tunning and a stroked engine.
Old Jun 3, 2003 | 11:28 AM
I have a 381 with a mild solid roller, and I don't run a knock sensor..... but then I also don't run the GM PCM. The guys that do my tuning told me that they have not had a lot of luck with the KS and solid rollers. They have looked at some fairly sophisticated filtering systems, with no success.
On the other hand, when this topic has been posted before, I have seen at least one person reply that they run a KS with a solid roller and have absolutely no problems.
Go figure......
Old Jun 3, 2003 | 01:19 PM
kmook's Avatar
Advanced Tech Moderator
Go figure......
Ditto. I ran a solid roller and had to disable the knock sensor completely via tuning, because i was seeing a lot of knock pickup even at idle. Most solid roller people i talk to say they had to do this (yes these are street cars). There are always a few like Fred said that say they use a KS fine with a SR...
Old Jun 3, 2003 | 01:50 PM
Mindgame's Avatar
A KS and a solid roller?? :blah:
I've never even tried it... current engine is KS!.
-Mindgame
Old Jun 3, 2003 | 01:52 PM
kmook's Avatar
-Mindgame
Alan, you N00b it's !KS
Old Jun 3, 2003 | 01:54 PM
Mindgame's Avatar
Red face
LOL..... hell I never pay attention to the delete stuff. But now I know !KS.
Thanks boss.
-Mindgame
Old Jun 4, 2003 | 12:39 AM
mastrdrver's Avatar
Everyone I have seen running a sr say they cant run one bcuz of the KS goes crazy.
Old Jun 5, 2003 | 08:39 AM
LT1 S-10's Avatar
So it looks like the KS needs to be eliminated huh.
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
Wicked
Jul 25, 2002 04:19 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
