What gear ratio for street/strip?
Old Jun 4, 2003 | 07:39 PM
93z28vig's Avatar
I need help in selecting some rear end gears for my daily driven seldom raced 93 Z28 that has a LT4 Head and cam package, SLP 1 3/4" shorties, corsa cat back, random tech cats, 2800 rpm vigilante torque converter and a possible 75-100 shot of Nitrous. I have it narrowed down to 3.23, 3.42, and 3.73 the car currently has 2.73 in the rear any input would be appreciated.
Thanks a lot
Mike
Old Jun 4, 2003 | 07:41 PM
wicked_95z's Avatar
3.73's are the popular choice for A4's. But seeing as how you rarely race, I would suggest 3.42's
Old Jun 4, 2003 | 08:27 PM
PoorMan's Avatar
2.73 to 3.42 here. I like it. Wouldn't want it reving any higher for the freeway driving I do. Don't forget to get a new reluctor ring if you go with a 3 series carrier. They are different and the ABS won't work if you leave the 2 series ring in. Ask me how I know. Man, your car is going to run soooo much better after the gear change if you have all those mods installed already. How is you low end now??
Jeff D.
Old Jun 4, 2003 | 08:43 PM
93Z4ME's Avatar
I second the 3.42 selection, it will put you at
~5800rpm @ 100 mph in third (through the traps)
~3150rpm @ 70 mph & ~4500 rpm @ 100 MPH in drive and
~2300rpm @ 70 mph in OD
3.73 it will put you at
~6350rpm @ 100 mph in third (through the traps)
~3400rpm @ 70 mph & ~4900 rpm @ 100 MPH in drive and
~2500rpm @ 70 mph in OD
Old Jun 4, 2003 | 09:39 PM
107's Avatar
107
Could someone explain to me the difference between a 2 and 3 series carrier? I have a 2.73 car and understand mine is a 2 series, if I use the gears off a 3.42 car will they work? Are all of our cars 2 series?
Old Jun 4, 2003 | 09:44 PM
Derrick Redd's Avatar
I would go 3.42's with the nitrous. 3.73's if staying NA. I have 3.42's and they work well with the NX 150-175 shot.
Old Jun 5, 2003 | 02:19 AM
96redformula7's Avatar
I just got some 3.73's that i am gonig to put in my car within a few days here. So you all are telling me that I will be doing the quartermile while at the redline . I seemed to think that I would be able to still hit over 100 in 3rd gear.
The Calculator here says that you are WRONG
http://www.fbody.com/calc.htm
Old Jun 5, 2003 | 02:46 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
da wha!!?!?!
my third gear DOESN'T KICK IN until 96 mph.... at WOT....
Old Jun 5, 2003 | 02:54 AM
Dmx4ever3's Avatar
Question GEARS
I HAVE A SET OF 3.42 GEAR ILL SELL YOU FOR $100 LET ME KNOW IM TRYING TO SELL THEM AS FAST AS I CAN IF YOU WANT THEM ILL WILL TAKE PAYPAL AS PAYMENT
Old Jun 5, 2003 | 03:31 AM
bruecksteve's Avatar
Go here for a great calculator to compare gear ratios.
Old Jun 5, 2003 | 03:33 AM
revtime's Avatar
I have 3.73s in an A4 and I don,t come near 6350 in third through the traps. I love my 3.73s but I had to buy some traction aids.
I have my rev limiter set at 6250 and I don,t ever hit it in third goin through the traps.
Old Jun 5, 2003 | 06:50 AM
rskrause's Avatar
Moderator
With a 25.9" radial, the typical diameter for street 4th gen's (no tire growth) in 3rd gear (1:1).
3.42: 6,000rpm = 135mph
3.73: 6,000rpm = 123mph
To give you a good answer to your question, it would help to know how high your combo revs.
Rich Krause
Old Jun 5, 2003 | 08:30 AM
IDOXLR8's Avatar
I would go with a 3.42 if I were you.
Old Jun 5, 2003 | 08:58 AM
94droptopz's Avatar
3:73 is the best all around street strip gear. were not talking about that big of a difference between the 2 but imo id use the 3:73.
as for the carriers,most a4 came with 2:73 gears and a 3:08 and lower carrier.
most of the 6spd cars acme with 3:42 gears and the 3:08 and higher carrier.
you can buy gears for either one as long as its a match. im saying you can buy 3:42 or 3:73 gears but you HAVE to buy them made for a 3:08 and lower carrier to be installed in your car.
HarleyZ28
Oct 5, 2015 06:23 AM
anmar A
May 2, 2015 06:59 PM
thenewkid
Apr 12, 2015 07:42 PM
Jul 4, 2005 05:00 PM
