Big Boy Fuel System ???????????????????'s
whats up guys i am having a little hard time trying to set up my fuel system, let me let you guys know what i am doing here big system with
this is for an lt1 engine
A1000 pump
and 13101 regulator
10an feed from rear to front
i have my stock rails modified with the crossover pipe deleted with 8an feeds on the front of the rails on each rail then on the rear of the rails i have 6an fittings welded up for the returns my ? is how do i plumb this on the regulator do i have to run a seperate return line to the rear now or do i just Y the two 6an coming out of the back of the rails going ot the return port on the back of the regulator? thats my ? or do i have to do something else.also the i was told that this regulator is boost referenced 1:1 just hooking up the vaccum is this true?any help that can be given would be greatly apprecaited.
__________________
A1000 pump
and 13101 regulator
__________________
If im reading this right there are 3 ports on the regulator. Two inlets and one return. Come off each fuel rail to an inlet and the return line to the tank. Never plumbed one but that makes sense to me
http://static.summitracing.com/globa.../aei-13101.pdf
Jul 4, 2005 05:00 PM
