Big block in a TA
Old Jan 10, 2006 | 10:14 AM
NOSfedstang's Avatar
Big block in a TA
I have a 1996 TA vert. Its got 10point cage, full tublar front and rear suspension, fuel system and all the mods that follow. As of right now it has no motor in it. I want to do a big block in it. Just wondering if any of yall had any info on the setup.........I want to go in the 9's NA and 8 on the spray.....Any help will be thankfull. I can get custom headers made for it no problem from a friend. I was thinking of buying a long block from somebody. What do yall think? ANy links?
Thanks......
ps- I would also like to run a motor plate instead of motor mounts......
Old Jan 10, 2006 | 10:52 AM
valter's Avatar
Re: Big block in a TA
Too much trouble.
http://home.bellsouth.net/p/s/commun...geid=28387&ck=
Old Jan 11, 2006 | 10:24 AM
cwaldt's Avatar
How can you say its too much trouble if you've never done the conversion. There are several manufactors that make K-members that will allow you to bolt this right up, they even make the trans crossmember for what ever trans you pick. Yes it's alot of work but no more than changing out an LT-1, trans, rear end, k-member etc.. You just make a well thought out plan and decide what parts you want and go from there. Also expect a few trips to the auto parts store (which occurs in any type of engine change). With a well thought out plan and shopping list anything is possible. Plus the power to money ratio makes this an interesting deal.
Old Jan 11, 2006 | 12:10 PM
Evil Eric's Avatar
Originally Posted by valter
I thought the end result was awesome and worth all the trouble he went through. How many big block 4th gens are there right
Old Jan 11, 2006 | 05:32 PM
1racerdude's Avatar
It's done all the time.
Just takes cubic bucks as everything has to be made for it.
Ya can't get in the 8's with a small block??
Some are doing it regularly.
Put spray on Joe O's car and see how deep into the 8's it will go or Steve Quinn's,or Mindgame.
Old Jan 11, 2006 | 06:59 PM
SStrokerAce's Avatar
If you do it.... please put a big block in there worth the time to do all this crap.
OVER 800hp NA... other than that it's a waste of time.
Bret
geinsteder
May 6, 2015 06:02 AM
MadMav
Feb 6, 2015 11:02 PM
OutLaw305
Jul 26, 2002 03:47 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
