A better Opti Spark?
Old Oct 21, 2003 | 09:59 PM
  #16
TwinTurboPower's Avatar
seriously, mine went 150K before it went out
Old Oct 21, 2003 | 10:33 PM
  #17
DarkRider's Avatar
I just ordered the dynotech opti today just because I wanted the vented model and a better sealed unit - plus you have to do much more work to the car if you want to convert to the vented unit on a 94- Z. I figure it is worth the extra money and it is completely rebuildable so that you do not have to buy the whole unit again.
I'll keep you posted on how my dynotech is working out
peace
Old Oct 21, 2003 | 10:54 PM
  #18
speed76demon's Avatar
I'd kill for a $150 dollar opti i have the non vent pos i believe atleast thats whats on there now some expensive piece
Old Oct 22, 2003 | 05:15 AM
  #19
BES-383's Avatar
Originally posted by jasons93z
You guys must abuse the hell out of your cars. Mine is stock opti with 85k on it with no signs of it going. And i have a hard foot. I think you all are just retarted and not installing them correctly
Retarded? Don't think so. Not installing them right. Wrong. We just have engines that rev over 6,800 RPMs. When was the last time you reved your motor to 7,500? If not I assume YOU do not know what your talking about.
Please keep this thread going. Am looking for the answer like every one else.
Old Oct 22, 2003 | 05:19 AM
  #20
jasons93z's Avatar
Well u got me there . I dont rev over 5900rpms because i dont have a huge amount of mods. If you guys are having that many problems with the opti, then wouldnt it be LOGICAL to change. Like get the coil pack conversion kit. Its stupid to change an opti that often considering they are not cheap. Since you think you know so much, im suprised you didnt think of it.
EDIT: When i said you guys are retarted and not installing right, it was a joke, hence the part of the sentence.
Old Oct 22, 2003 | 05:24 AM
  #21
BES-383's Avatar
Well u got me there . I dont rev over 5900k because i dont have a huge amount of mods. If you guys are having that many problems with the opti, then wouldnt it be LOGICAL to change. Like get the coil pack conversion kit. Its stupid to change an opti that often considering they are not cheap. Since you think you know so much, im suprised you didnt think of it.
Just to show your ignorance of the subject. You still use the opti with the (coil pack conversion kit) as you call it.
Old Oct 22, 2003 | 05:28 AM
  #22
jasons93z's Avatar
YOU HAVE NO IDEA WHAT YOU ARE TALKING ABOUT. The ls1 uses a completly different ignition system(using coil packs). The coil pack conversion changes your ignition requiring you NOT to use the opti. You would use 1 coil pack per cylinder. Again, stop looking stupid. You abviously have no idea what u r talking about.
Old Oct 22, 2003 | 05:29 AM
  #23
BES-383's Avatar
You are so funny
Old Oct 22, 2003 | 05:33 AM
  #24
BES-383's Avatar
Please read this and you MIGHT be informed of whats going on here.
LTCC set up
Old Oct 22, 2003 | 05:38 AM
  #25
jasons93z's Avatar
LTCC set up
That is exactly what im talking about. I dont get what you mean . This would abviously be a better ignition setup then the opti since you rev higher. You were simply stating that the opti was the coil conversion kit which is not the case
BTW, you dont use the opti with the conversion kit. thats the whole point of it.
Old Oct 22, 2003 | 05:41 AM
  #26
BES-383's Avatar
I see you can't read.
Quote from the ad.
# Benefits of the system are: extended opti life
# much stronger ignition at high RPM/boost
# built in adjustable rev limiter / two-step
# built in adjustable N2O / boost retard.
# It's just plain cool.
Now why does it say EXTENDED opti life.
It still uses the optical module in the Optispark, but no high voltage is passed through it, removing the source of damaging ozone that eventually leads to Optispark failure.
Old Oct 22, 2003 | 05:44 AM
  #27
jasons93z's Avatar
Quote from the ad.
Its the wrong link then. Let me ask a question. Does the LS1 use an opti? NOOOOOOOO. This conversion basically converts the lt1's ignition to the ls1's which has NO OPTI. Its either someone that is misinformed or
Old Oct 22, 2003 | 05:47 AM
  #28
BES-383's Avatar
I give up you know it all.
Old Oct 22, 2003 | 05:51 AM
  #29
jasons93z's Avatar
I not trying to dog u. Im just stating the facts. Dont be a smarta$$ about it, im trying to HELP you. The correct conversion kit DOES NOT use the opti. Read up a little more and youll find the right one
  #30
BES-383's Avatar
Please read this thread all the way through,and you might understand.
opti alternative
