Which is a better camshaft Hot cam or cc306??
Old Jun 24, 2004 | 07:15 PM
detroit1994z28's Avatar
I just had the lt4 hot cam installed but I'm now thinking I should have gone with the cc306. Is the cc306 more noticable in power difference. Also What rpm range does the hot cam really work best to. 3 grand to about what rpm??? - Also is the cc306 allot more aggressive sounding. How much extra horse would I have got with the cc 306??
Old Jun 24, 2004 | 07:27 PM
simple's Avatar
totally different animals meant for different things
306 is a topend cam
Hotcam was made for showroom stock type racing and has a decent powerband thruout
most wish that they would have gone 'bigger' after installing the Hotcam but dont be fooled it is a good lil cam that can make a fair amount of power with a good tune! speaking of, do you have a tune yet?
there is no set numbers for "this camshaft gives X amount of power more then Y camshaft" its all about the combination of parts and the tune
Old Jun 24, 2004 | 07:45 PM
Dave88LX's Avatar
Not to be an *** but a search will bring up tons of info on this very same subject.
Check out the tech page in my sig too
Old Jun 24, 2004 | 09:43 PM
truedualws6's Avatar
LMAO
Old Jun 24, 2004 | 10:45 PM
HardcoreRM125's Avatar
TRUEDUALWS6 ~ Your puttin down some serious #'s for stock cam, stock heads, No Headers ...
Just wondering but what do you have done to that thing ?
Old Jun 24, 2004 | 10:50 PM
Hardcore, here is the list of engine stuff. Basically bolt-ons except for the rockers.
True dual 2.5” exhaust w/Magnaflow OBDII catalytics and Dynomax Ultraflow muffler; TPIS airfoil, TPIS adj. fuel pressure regulator, March crank pulley, TPIS plug wires, Bosch platinum +4 plugs, Accel 300+ digital CDI ignition, Comp Cams pro-magnum 1.6:1 rockers (guideplates, studs, pushrods), GMPP No. 12551483 valvesprings (caps, locks), GM LT4 knock module, Granatelli MAF, Hypertech HPP+ program, Hypertech 160° thermostat, K&N air filter and throttle body coolant bypass.
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
