best way to race in a 94 Z28 A4
Old Apr 3, 2004 | 11:01 PM
BlackMagikLT1's Avatar
Question best way to race in a 94 Z28 A4
Hey guys, well thats my question, i just got the car, so im still trying to figure out little things about it. So just how exactly should i race the car, in drive, overdrive, or manually upshift????? let me know, its an automatic 94 Z28
Old Apr 3, 2004 | 11:02 PM
Bersaglieri's Avatar
Overdrive is fine but you prolly wont get to 4th either way. I dont see much of an advantage manually upshifting. Good Luck!
-Dustin-
Old Apr 3, 2004 | 11:04 PM
Zack's Avatar
no need to MANUALLY shift an ELECTRONIC tranny
Old Apr 3, 2004 | 11:08 PM
RyanS_Z28's Avatar
get it programmed for better shift points. overdrive is more powerful at the bottom definently i think. you could also look into getting a shift kit. manually shifting hurts your tranny i think.
other than that, when the light goes green, and the other guy is spinning his tires, that means its time to go, but of course you wont spin, because you'll be crossing the finish line
Old Apr 3, 2004 | 11:17 PM
scoobysnax83's Avatar
push the gas....
M6's Rule....
Old Apr 3, 2004 | 11:19 PM
RyanS_Z28's Avatar
Originally posted by scoobysnax83
push the gas....
M6's Rule....
i was thinking that but didnt say it. i thought of some actual INSIGHTFUL info to give him
Old Apr 3, 2004 | 11:20 PM
94TEALz's Avatar
From what I understand manually shifting it burns the clutches due to low line pressure. Leave it in drive and go.
Old Apr 3, 2004 | 11:24 PM
RyanS_Z28's Avatar
if i were you id put in an aggresive cam, stage 3 heads, stroke it to 383, rebuild the tranny, get a Moser 9", drag slicks, then i think youd be ok to race
Old Apr 3, 2004 | 11:31 PM
well i actually wanna know this because im taking it to the track on wednesday, and i want to run a couple of times. So which is it, drive, or overdrive, oh and BTW my car is bone stock.
Old Apr 3, 2004 | 11:32 PM
I offer enough insightful info, that I can be a smartass every so often. Tonights my night. Let me have my fun...
Old Apr 3, 2004 | 11:46 PM
RyanS_Z28's Avatar
do one with overdrive and one with just drive, see which is faster. i reckon drive will be faster
Old Apr 3, 2004 | 11:50 PM
rock1501's Avatar
push the gas....
M6's Rule....
Autos are faster
Old Apr 3, 2004 | 11:54 PM
RyanS_Z28's Avatar
i have an auto but i totally disagree there. unless you have a badass auto you will get killed by a manual. they are like .6 faster in the 0-60 arent they?
Old Apr 3, 2004 | 11:58 PM
why exactly would drive be faster?? sorry if these are stupid questions, but i just got the car a cupple weeks ago
Old Apr 4, 2004 | 12:00 AM
rock1501's Avatar
The M6 is only faster bone stock cause they come with a bigger(numerically) rear gear but autos launch way better.
no they are not .6 faster 0-60.Do you have any idea how much of a difference .6 of a second in 0-60mph is?Thats just huge
