Best way to pump gas out of tank?
Re: Best way to pump gas out of tank?
dont use your mouth with gas. Chances are since its been in soo long, a lot of it has vaporized and you will breath in the fumes without actually drinking the liquid. Also its very easy to mess up. I know someone that died from that.
Originally Posted by KPZ-28
I wonder if you could use the 1/2" hose alone and start the siphoning with blowing in the tank with an air compressor some what like the Mtrhds94Z method?
I should think it would push it out the fuel line and if you unhook it where the filter is you could run it into gas cans..
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
dmaastr
9
Jul 1, 2002 02:22 PM
