best shocks and springs for comfortable ride
Old Nov 24, 2003 | 10:09 AM
  #16
Fatdog's Avatar
Cool
Might check SLP new car take offs,the last time I checked it was about $100.00 for all for corners(springs and shocks).My cd player used to skip over bumps as well.I would maybe try a 6-cd changer (maybe trunk mounted)I have seen them for about $120.00.Hope this helps(Speed Legal Performance).
Old Nov 24, 2003 | 10:44 AM
  #17
scoobysnax83's Avatar
Wait a minute, are you saying all four corners for $100. Where do I sign up Would you mind telling me where you found these. I mean $100 a corner isn't even bad
Old Nov 24, 2003 | 11:24 AM
  #18
F Carline 94's Avatar
Take offs
Just got mine in last week. I was also suspension day dreaming, but this deal is WAY too good to pass up. Stock ride quality will do fine for 85 bones
Sean
Old Nov 24, 2003 | 11:26 AM
  #19
www.stranoparts.com
Part Number: BIL-B46-1913/14
Type: Bilstein HD
Brand: Bilstein
Area: Front & Rear
Price: $329.00
This sounds like a pretty good deal to me. I should be able to use stock springs with these. Or maybe the Eibach Prokit. But this seems like a good deal.
Old Nov 24, 2003 | 11:27 AM
  #20
Originally posted by F Carline 94
Take offs
Sean
WOW, Forget what I said above that is the deal of the century. How can you pass that up for $85. Thanks for showing me that. You are the man.....
Old Nov 24, 2003 | 12:03 PM
  #21
carlos64030's Avatar
Originally posted by scoobysnax83
Wow, you're totally missing the point. Must be the fact that its so late at night.
No dude, I understood what you meant, I was just having horrible flash-backs.
Old Nov 24, 2003 | 02:20 PM
  #22
BigRich's Avatar
the 94 Z28 stock springs are softer than the Eibach ProKit
i know cuz that's what i got. if you want ride comfort instead of ten/tenths performance, get new stock springs (or 1LE springs, but i think they are higher rate than stock 94Z) and KONI single adj. shocks
you can turn the rebound full soft F & R for soft ride/drag strip, or turn the fronts up to 8 or 9 and the backs up to 1 or 2 for higher speed driving.
lowering tire pressures to 28-29 psi all around will help your ride comfort as well
blkWidow
Sep 6, 2015 05:17 PM
canbaufo
May 17, 2015 10:35 AM
timmy39120
May 2, 2015 05:12 PM
Charged
Sep 25, 2002 09:28 AM
