best shocks and springs for comfortable ride
Might check SLP new car take offs,the last time I checked it was about $100.00 for all for corners(springs and shocks).My cd player used to skip over bumps as well.I would maybe try a 6-cd changer (maybe trunk mounted)I have seen them for about $120.00.Hope this helps(Speed Legal Performance).
Would you mind telling me where you found these. I mean $100 a corner isn't even bad
www.stranoparts.com
Part Number: BIL-B46-1913/14
Type: Bilstein HD
Brand: Bilstein
Area: Front & Rear
Price: $329.00
This sounds like a pretty good deal to me. I should be able to use stock springs with these. Or maybe the Eibach Prokit. But this seems like a good deal.
Type: Bilstein HD
Brand: Bilstein
Area: Front & Rear
Price: $329.00
Originally posted by F Carline 94
Take offs
Just got mine in last week. I was also suspension day dreaming, but this deal is WAY too good to pass up. Stock ride quality will do fine for 85 bones
Sean
Take offs
Sean
the 94 Z28 stock springs are softer than the Eibach ProKit
i know cuz that's what i got. if you want ride comfort instead of ten/tenths performance, get new stock springs (or 1LE springs, but i think they are higher rate than stock 94Z) and KONI single adj. shocks
you can turn the rebound full soft F & R for soft ride/drag strip, or turn the fronts up to 8 or 9 and the backs up to 1 or 2 for higher speed driving.
lowering tire pressures to 28-29 psi all around will help your ride comfort as well
carguyshu
Jan 22, 2017 11:19 AM
Charged
Sep 25, 2002 09:28 AM
